Under cabinet outlets - Local code issues?
rgonyer
New member
Okay sorry for the somewhat newbie question. I am re-doing my kitchen (new cabs) and I am one of those annoying people that loves a clean no outlet look on the backsplash. What I'd like to do is mount some outlets facing down from the cabinets.
While I am an electrical engineer, I do PLC programming 90% of the time for my job, so my code knowledge is somewhat limited.
From my reading here, I should be okay as long as my outlets are no higher than 20" above the counter top.
I just got off the phone with out county inspector (Scott County, Iowa). He says that the outlets must be 18" or lower (no minimum), but if they are mounted facing downwards, they must be 12" or lower. He said he thinks it's crazy too, but that's what the code states.
After reading here, he seems to be wrong. Could this be a local code that is more strict than the NEC?
Thanks for any help!
Your electrician should know the answer to this question.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
