mickeyrench
- edison, n.j.
when working with ac cable on under cabinets lighting does using ac cable limit you to thbout 8 e choices of lights you can use when you have 8 locations? thanks for the help
I suppose if you feel the overwhelming need to use type AC cable, yes. Be advised that some hardwired under cabinet lights, and in particular many puck lights, are only adaptable to type NM cable. I'd suggest putting your eyeballs on the proposed fixture, or at least get a cut sheet, before you get your heart set on a particular wiring method or types of fittings.mickeyrench said:yes it is . it's about using ac cable with duplex connectors and trying to hide cables from view. is this the way it's done?
I have "hidden" a box in the cabinet over the stove....each UC light gets one cable back to JB.mickeyrench said:it's about using ac cable with duplex connectors and trying to hide cables from view. is this the way it's done?
celtic said:"hidden" meaning...1900 box/appropriate ring or surface mounted 1900
stickboy1375 said:I highly recommend 1 wire per fixture....
iwire said:Oh man.....you mean I wont have to randomly pull down upper cabinets in search of a box that may not even exist.
You take all the challenge out the job.
stickboy1375 said:Hehe... yep, always gotta watch the wording you use around here...
On a really tough kitchen remodel I once, begrudgingly, had to put an 8x8 junction box behind a removable aluminium backsplash plate that was installed behind the range. Even though it was legal, as it was accessible, I was ashamed to have done such a thing. I did, as a courtesy to someone in the future, write this information inside the panel cover.celtic said:I'm convinced....lower cabinets is the way to go
celtic said:morning...figured he's on at least his third pot of coffee....
celtic said:
Hi Bob...the usual?
As long as I get paid...I'll do it a hundred timesstickboy1375 said:How'd you like to do that twice?
stickboy1375 said:next thing you know they tore it down and rebuilt it a touch farther back from the road... How'd you like to do that twice?
