I have a customer who has purchased a machine for his business which requires a 50 amp 3-phase 480 volt feeder, he also went and purchased a 75 KVA dry transformer to step his voltage up from the 208 3-phase he has availiable from an existing 3-phase 200 amp load center. My problem is I can only get a 125 ampere breaker in this panel to feed this 75 KVA transformer which should give me 54 amps at the high voltage side, my question is would this be a code violation and is the transformer output proportional to the input, will the transformer operate properly?
