THE SITUATION IS BAD UNDERGROUND CONDUIT BETWEEN 2 LIGHTING POLES!
THE FIX IS TO REPLACE ALL BAD CONDUIT WITH NEW GALVANIZED CONDUIT USING THREADED COUPLINGS,ERICKSONS ETC.
THE PROBLEM IS CAN YOU USE A THREADLESS COUPLING ON THE LAST PIECE BECAUSE YOU CANNOT GET THE OLD CONDUIT OUT OF THE LAST THREADED COUPLING HIS IS LOCATED ALMOST AT THE BASE OF THE LIGHTING POLE?
