I'm curious which way the majority of people deal with buried cable in the Northeast, where we're subject to frost heaves and the frost line can easily be several feet deep (too deep to easily dig that deep).
So consider an existing outdoor outlet attached to a house, and say you want to extend the circuit underground for 15' or so and then come up to a new outlet in the yard somewhere. Say the outlet is supported directly on two PVC schedule-80.
Choice #1: PVC all the way. Expansion coupling on the vertical run down from the existing outlet because of potential frost heaves. Schedule 80 on the two vertical runs, Schedule 40 on horizontal run.
Choice #2. Same as above, but Carflex on the buried horizontal run.
I've always done choice #1 and never really had a problem. I've heard that some people have trouble with the PVC cracking in winter, so that's why they go to Carflex on the buried run. (there's no way I take the time to dig deep enough to get below the frost line here).
Do most people do Carflex to avoid PVC cracking from frost heaves?
Thanks,
Joel
Thanks,
Joel
