W wchild1520 Member Location Palm Springs Ca. May 14, 2013 #1 Are there any requirements for clearence from other utilities when installing underground conduit , I found cover requirements .
raider1 Senior Member Staff member Location Logan, Utah May 14, 2013 #2 There are no spacing requirements for underground raceways from other systems in the NEC. Check with the other Utility companies they may have local rules. Chris
H Hv&Lv Senior Member Location - Occupation Engineer/Technician May 14, 2013 #3 There are some in the NESC, but it probably doesn't apply to your installation...
Ponchik Senior Member Location CA Occupation Electronologist May 15, 2013 #4 As suggested you need to check with your local power company for clearances. Also make sure you call digalert before you do any digging.
