I have three questions regarding underground conduit and I am wondering if you would be able to provide a brief sentence on each. Thank you.
1) is there a minimum required size for underground conduits? IE- If the cables I need to run only require a 2" conduit, is that acceptable or must it be no smaller than a certain size, say 3"?
2) what are the rules for transition from underground PVC to above ground, does it need to transition from PVC to RGC above ground?
3) what are the conditions when the underground conduit must be encased in concrete?
Thanks
Thanks
