Underground duct banks
frankelectric
Ponce, PR.
Hello:
I want to know if the THHN or THWN wire can be installed in underground duct banks. Also if the outer cover of this wire is damaged or broken; the wet proof application is loss?
Your comments will be appreciated.
Frank Rodriguez
Re: Underground duct banks
Underground installations of conductors or cables in raceways must be listed for use in wet locations. (300.5(D)(5)) The insulation types with a "W" have this listing.
I believe damaged or broken coverings on conductors violates Article 110.3 and should be removed and not used.
The outer covering of THHN and THWN has nothing to do with the water proofing or the dielectric constant of the insulation.
This information is available from most manufacturers. My information comes from the Southwire catalog, I'm sure if you go to their website you can probably find this same info.
If it is a nylon covering it is more apt to absorb moisture.
Roger
THWN:
Insulation : Flame-retardant, heat, abrasion, and moisture-resistant PVC with polyamide nylon
STANDARDS:
UL 83 : Thermoplastic insulated wires and cables
TYPE THWN : 75C wet or dry
APPLICATION:
General purpose building wiring insulated with polyvinyl chloride(PVC) and covered with a tough protective sheath of nylon intended for lighting and power circuits wiring as specified in the National Electrical Code. The wire may be operated at 75C in wet locations.
Do you know what its purpose is then? :confused:
Bryan,
not really, except possibly to help protect the thin insulation itself, 310.13.
I remember an argument on this forum once where one poster said he was told from a manufacturers rep it was only to assist in pulling it thru a conduit.
I have a hard time believing this is the case, but who knows.
Roger
Note 1 to Table 310.13 states: "Some insulations do not require an outer covering."
Does this mean that if an outer covering is listed, it is then required? :confused:
Look at the report of a Goerge Washington Chapter IAEI meeting where the speaker was the Technical Director of Southwire's electrical division. (you will have to scrol down about 10 pages to get to the report of the Nov 18, 2003 meeting) He said in part:
Unless conductors are exposed to gasoline or oil, or submerged for an extended period we're talking many months--the nylon covering offers strictly a mechanical protection, Dave explained, with the underlying PVC supplying the dielectric properties as Gil had told us. The nylon actually is stripped away for the UL acceptance test. Therefore, if the nylon is scraped off, but the plastic underneath is intact, an appropriate response usually is "Good; it's done its job," and a green tag.
Don
