Pool guy R
New User
- Texas
- Pool contractor
We are building a small house at a lake that has a 200 amp feed through panel at the meter pole at the street. We would like to install an underground feed to a 150 amp indoor panel at the house. Electricians want to run an SE 2/0 wire. I would prefer to run a 2/0SER RHH,RHW-2.
I believe that would give us a fire rated cable where it enters the house. I believe SE is not rated for burial. Any thoughts or recommendations?
Also, if the 150 amp panel is considered a sub panel, would I need a four conductor wire? A separate ground should be installed at the house.
