ceb58
- Raeford, NC
Is there another code article other than 300.5 (D) (3) that requires marking ribbon in the ditch. Have an inspector failing a install because there was not RED marking ribbon placed in the ditch over the conduit. The run is from a ground mounted solar array to the inverter. The wire is in ridged metallic conduit ( RMC ) at a depth of 12 inches which well complies with table 300.5. These conductors are not service conductors and do not meet any other requirement in 300.5 (D) (3).
