PabloO
- San Diego, CA
- Electrical designer
Hi, we're trying to run independent wires to 12 or 20 similar-to-each-other loads, 1-ph, 240 V, up to 60A each, that might not be coincident in most of the cases, and that are restricted to 5 being coincident at full load. We'll go underground with individual PVC piping for each load, or as much as 2 loads bundled together (4 wires + ground). How should the bundling correction factor be applied if the pipes will go side-by-side, one with one load circuit?, like:
ooooo
ooooooo
in 2 or more beds/lines inside the trench (planning it to be min 24" depth); we have not found how should this correction be considered, if it's the same as if all the wires will go bundled together in a bigger pipe, or if having individual pipes helps to reduce or eliminate the correction factorooooooo
