Underground Power Line
emendoza
New member
How deep a Power Line should be from the surface ground, and Power lines wiring should be under a house and crossing at the middle of the house and back yard,
thank you
bennie
Esteemed Member
Re: Underground Power Line
NESC 353D2a Depth of Burial. 30 inches. 601 volts to 50 KV.
Check your property description for an easement. Power lines can run under a building, but it must be noted on legal real estate documents.
Contact your utility company.
