codequestion
Banned
- MD, USA
Engineering plans call for underground receptacle without GFI protection. Anyone have any idea as to who sell them or where in NEC underground receptacle article/section would be?
I don't know what you mean by "underground receptacle." :?
This is the only one that I am aware of: https://www.legrand.us/markets-solutions/outdoor/ground-box.aspx
AFAIK it is a fairly new product. Never seen one in the wild yet though.
I could be mistaken, but I believe I priced these and they were about $1000 each. Sounds like a lot, but when there aren't any other options.....
I see a risk that a damaged power cord plugged in could provide an air exit path, allowing the water level to rise at least to the height of the cord sheath break.
I don't follow you, the "diving bell" design doesn't depend on any sort of sealing around the power cord.I see a risk that a damaged power cord plugged in could provide an air exit path, allowing the water level to rise at least to the height of the cord sheath break.
The diving bell effect requires that the space inside the bell be airtight. A damaged cord could provide an air leak to the outside.I don't follow you, the "diving bell" design doesn't depend on any sort of sealing around the power cord.
Cheers, Wayne
Take a diving bell and run a hose from the inside to any point outside in open air and all the air will come out.A diving bell doesn't need to be water tight below the connections. Diving bells are by their very nature open at the bottom.
... about $1000 each...
OK, so not for the holiday lighting display. :lol:
Motel outdoor.The location of the receptacle along with voltage and amperage would need to be known for starters.
JAP>
I see it for ~$200 online at a couple places.
Search for "Wiremold XB814".
Clever design. I like the fact that it locks.
