Re: underground residential service 2oo amp
friebel,
I agree with you to the extent that I have seen some industrial concerns provide extensive training to their personnel and thus turn out some exemplary electricians, however, in my experience, their area of expertise is focused to the type of work they encounter daily. Likewise I have seen some knowledgeable residential electricians that can not make a saddle bend in conduit. In each case, the individual may be highly qualifed in their respective area, but have not had the opportunity to work in the others man's arena.
The best, experienced, residential electrician would probably be lost in your plant working on your MCC or 13kv switchgear.
From my experience in inspecting, the reverse scenario also takes place. Some of the installations I see that are wrought with code violations are residential where "uncle Frank", the plant master electrician, has done the wiring.
Unfortunately, as wise as he is, in his daily work he has not run NM cable, never seen a "stack-it" or encountered a specific spacing requirement for receptacles.
Although I'm sure they exist, the man (or woman) who performs with equal proficiency in both arenas is rare.
As a side note, despite some of the comments made about inspectors, I feel they deserve a great deal of credit as most have to have knowledge in most all areas of the Code.
