ishium 80439
I am looking at a job and was hoping I might be able to get a bit of advice to see if I'm on the right track.
The project is about a 7000 sf home. There is a transformer with meter pedestal about 250' away. The meter pedestal (provided by the utility) has (2) 200A breakers. There is currently (1) 3" Sch 40 PVC between the transformer and the homesite.
I was looking at pulling (6) 4/0 Cu THHN and (2) #4 Cu THHN in the 3". My question is what happens when we reach the house. Is there a cabinet that I can bring a 3" into that has (2) 200 breakers that I can terminate in? I've seen meter/ mains in that configuration but have never needed one with just breakers and no meter.
Also in this configuration do think it would be permissable to use SER from this cabinet to the panels in the house? Would this be considered service equipment since there is a disco in front of it? If not what wiring method would you recommed?
Thanks
Thanks
