jeff48356
- Livonia, Michigan
I've never dealt with this situation before, but I'm wiring a house with a brick bottom and siding top. The underground conduit must run up the brick part of the wall, but that is much too low to mount the meter base. It would have to be installed on the sided part. However, the brick ledge comes out 2" past the brick surface, then wraps back about 5-6" to the surface to be with siding. Do they make 2" PVC bent conduit assemblies for this purpose? If not, how difficult would it be to bend a piece of PVC so it fits the contour of the house up to where the meter base needs to be?
This would be a lot easier for everyone, and look a lot better, if they didn't cheap out and go with half brick and half siding. If this were my house, I would INSIST that they do the entire house in brick. Then I could simply use a couple of brick brackets and mount the meter base wherever I need it.
