JohnDS
- Suffolk, Long Island
- Electrician
Hello guys. I was hoping to get some insight on a future underground service. Right now there are utility poles on opposite side of street from house. The house that is getting the underground service has its own pole on property. Off that pole, is the service drop to overhead service. All the other houses also have their own pole. Homeowner does not want pole on property so i will need to shoot a bullet across road to nearest pole. Questions:
1) Besides for coordinating with utility to hook up to riser, do i need to check with village/town before i shoot?
2) a-Where would I find someone who has equipment to shoot?
b-Do they use a pipe sleeve under roadway or just pull my wires? I am using direct burial feeders.
3) This will be for a 400a service. I plan to use aluminum triplex. I believe if reading 310.15 correctly that 700kcmil will be proper for this. Is this correct?
Thanks.
Sent from my SAMSUNG-SM-G730A using Tapatalk
Thanks.
