My local utility will only "hit" or provide a single connection point to a building regardless of the metering arrangement. Utility conductors from the transformer on line side and the building service conductors on load side. Usually they run to a connection/tap box and the separate metering is fed from there (outside of building). I have a situation where there is no room on the wall either inside or outside of the building for a connection/tap box. Is there such thing as an underground connection/tap box? The service is a larger 3000A 208V 3-Phase.
