I have an apartment building that utilizes cold sequence metering. There is an 800 amp main breaker that feeds a meter pack for 12 utility owned meters with individual main breaker for each unit fed from the meter pack. The issue is the direct connection of utility lateral to the 800 amp main breaker. The utility pulled 350mcm al to the main. Where is the code section that deals with this situation? In the past, we have always required a tap can for our point of connection to the utility. Any ideas on this?
