I am looking at a job that needs to be installed soon in a classified building which I feel has violations. It has 4"-6" pvc or cpvc used as a means to get hose lines and such to a class 1 building from a non classified area , as soon as the cpvc enters the building the hose line and air lines go to there work areas throughout the building. there is no sealing fitting of any kind . Should there be ? Also is this a complient installation. We willbe installing some al conduit inside building and need seals at switch locations. How do mechanicas and plummers get away with this non sealing issue with the cpvc entering building from underground.
