Hello, my name is Mike and I am a Maintenance Tech. I AM NOT AN ELECTRICIAN.
I work on large pumps and motors. They are 1200HP 4160v. We had all of our switch gear rated and labeled, but I would like some clarification.
I have gotten conflicting info about our Arc Flash ratings.
I am trying to find out what PPE is required to operate the disconnect for the attached rated equipment.
Please let me know if more information is required.
Thank you
Based on your question, you first need to determine if you are even qualified to work on this equipment. The NEC and NFPA 70E, Standard for Electrical Safety in the Workplace define qualified person as follows:
Qualified Person. One who has demonstrated skills and
knowledge related to the construction and operation of
electrical equipment and installations and has received
safety training to identify and avoid the hazards involved.
Additionally, NFPA 70E states that a qualified person should be trained as follows:
(1) Qualified Person. A qualified person shall be trained
and knowledgeable in the construction and operation of
equipment or a specific work method and be trained to
identify and avoid the electrical hazards that might be
present with respect to that equipment or work method.
(a) Such persons shall also be familiar with the proper
use of the special precautionary techniques, applicable electrical
policies and procedures, PPE, insulating and shielding
materials, and insulated tools and test equipment. A
person can be considered qualified with respect to certain
equipment and methods but still be unqualified for others.
(b) Such persons permitted to work within the limited
approach boundary shall, at a minimum, be additionally
trained in all of the following:
(1) Skills and techniques necessary to distinguish exposed
energized electrical conductors and circuit parts from
other parts of electrical equipment
(2) Skills and techniques necessary to determine the nominal
voltage of exposed energized electrical conductors
and circuit parts
(3) Approach distances specified in Table 130.4(D)(a) and
Table 130.4(D)(b) and the corresponding voltages to
which the qualified person will be exposed
(4) Decision-making process necessary to be able to do the
following:
a. Perform the job safety planning
b. Identify electrical hazards
c. Assess the associated risk
d. Select the appropriate risk control methods from
the hierarchy of controls identified in 110.1(G),
including personal protective equipment
The last one includes knowing how to determine the correct PPE. If you don't know how to assess the hazard and select the appropriate risk control methods, including selecting the correct PPE, or if you haven't had electrical safety training, I would say you are not qualified to do the work and need to get electrical safety training as a minimum.
