zcanyonboltz
- denver
I know that the B phase of a Delta system is the high leg. Does the high leg only get used on a single pole breaker to supply 208V to that circuit? I am thinking about what voltage you would have or if this is even how its done if you had a two pole breaker with A and B phase or C and B phase? From what I've read a 3 pole breaker with ABC would be 240V, is this correct?
