bburn
New member
- Crawfordsville IN
Had some higher than expected electric bills in my shop so decided to check a few devices.
I have 490 line volts feeding a 30kva delta (480/240) transformer to run my 240V 3ph equipment. When checking voltage/amperage on my 240V 7.5hp table saw (no load) I had the following readings.
T1, 9.12A - 0V :?
T2 5.81A - 235V
T3 6.00A - 235V
I've never bothered checking before but doesn't zero volts seem odd. Or maybe it's normal for transformed power. It's not just that machine either. I also checked another 240V 3.5KV motor running off the same transformer and found a zero voltage leg on it as well.
T1, 9.12A - 0V :?
T2 5.81A - 235V
T3 6.00A - 235V
