SparkyAdam
- Oregon
- Electrician/Small Business Owner
I am working on a project for an industrial facility with 400 amps of three-phase power (208). They want to add one 200-amp service, bringing the total to 600 amps.
Currently, the CT Can is nippled to one main breaker panel and one knife switch disconnect, which feeds a nearby main lug panel. They want to add one 200-amp panel to the current system fed from a new mast. The current CT Can is wide enough to accommodate a third nipple to either a main breaker panel or a knife switch disconnect, but on the other side of the wall, a beam prevents me from placing anything there.
Can I route a 200amp feeder from the CT Can, through the existing knife switch disconnect, to a new knife switch disconnect placed where panel 2 is now? Or would I have to remove the knife switch and panel 2, and place a gutter that would nipple to two different disconnects?
