Fred B
- Upstate, NY
- Electrician
I know some of you deal more with the higher voltage systems so thought I'd ask here as my experience has been limited to up to 480 and under 600A.
We seem to have a lot of ungrounded primary in our more rural areas around here. What safety systems are at work for the primaries when you get a short to ground on the system like a tree or say a car accident that breaks off the pole? A lot of the one line, no neutral, lines feeding down for several miles sometimes to one or more transformer(s) that then derives it own neutral for a 120/240. Will the fuse break blow with such a high resistance ground potential?
Any additional considerations or caution needed with this type of system vs a wye system such as potentially being "worse" with only a high resistance earth only grounding, that might be different when dealing with the 120/240?
