A friend of mine called me today and ask me about an ungrounded delta. The voltage is 240 volts. He told me he took readings from phase to to?ground and come up with the following voltage readings.
A-B 450 volts
B-C 435 volts
C-A 215 volts
Is this possible? Can the voltage to ground be higher than the phase to phase voltage? I was always told that the voltage to ground on an ungrounded delta can be anything, but I did not think the voltage could be higher than the phase voltage.
Hpec
A-B 450 volts
B-C 435 volts
C-A 215 volts
Hpec
