My son and his wife recently purchased a home in Lenexa, Kansas. The home was built in the 50's, recently renovated (flipped) and currently has a mixture of 2 and 3-wire 120V branch circuits, with probably all circuits feeding receptacles still 2-wire. However, all receptacles are grounding type (3-wire). The home was inspected prior to purchase and the ungrounded (as well as unmarked) receptacles were noted but deemed acceptable due to the age of the home. There are no GFCI breakers in the panel and while there are GFCI receptacles in the kitchen (I believe also ungrounded), none of these GFCI's appear to be protecting the other recepts. per Art. 406(D)(3)(c). Similarly, I found ceiling light fixtures on these same circuits with no ground. Is it likely that a local authority would deviate from the NEC in what appears to me to be a dangerous manner, or is it more likely the inspector is misinformed?
