Jordan_
- Los angeles
- Contractor
Hello, and excuse me if I use the wrong terms- I am not an electrician! I leased a new place for my shop and I'm trying to understand if my electrical system
Here is what I know:
-It's 3 phase 208v
-the ground and the neutral are bonded in the main breaker box under the meter
-there's no grounding bus in the newer panel and there's none of the outlets has a ground wire (only hot and neutral)
-when I plug in an outlet tester it shows that the outlet is grounded correctly
What am I missing here?
Thank you
-It's 3 phase 208v
Thank you
