I feel the solution is....
77401 said:
MXS
Very well written, you spent a lot of time thinking about this.
Never mind Tampa Jims, Rude remark regarding your field of expertise.
I agree with your view of the problem(s)
But what is the solution?
First off, I don't think Tampa meant to be (or was) rude, really.
My profile doesn't include the fifteen years I have spent working with various EC's, my last EC considered me to be at the journeyman level in knowledge. My
current occupation is as a Cinema Service Tech, running my own company.
So, no offence taken, Tampa!
On both this site and others, I have noticed it was maintained in MANY instances that the Code is not intended to be retroactive, i.e. you are in many cases not
required to bring older installations up to modern Code, as long as there is no damage or danger already present.
So, if you are simply
replacing exisiting receptacles, without making any additions to the circuit, why should the Code force you into using a gfci? (Except of course in the currently required locations, like baths, kitchens or outdoors.) Or re-installing an "outdated" receptacle design?
I reiterate that I'm NOT trying to argue that it would not be safer to use a gfci, but why force it on
every receptacle in a residence when it was
never required to be on
every receptacle in the first place? (and let's leave AFCI's out of this for now, please!)
So I submit that simply replacing devices, which in most cases is a BIG step up in safety, is an area where in this case the Code needs to get in step with reality.
Honestly, how many homes/apts. in the U.S. (not to exclude the rest of the world, but this is an NEC issue) do you all think are still wired with the older two-wire romex? (Let's say millions for giggles.) And how many, of those homes/apts., have had the receptacles changed by the homeowners/landlords? (millions again) And let's not forget that many jurisdictions DO NOT require inspections or permits for device change-outs? And how many of those millions who have done device changeouts bothered to locate and spend the extra cash on two-prong recpts? Maybe a hundred if any.
And the kicker: How many, of those millions, have had reportable, statistically significant incidents of shock/fire/other hazards, simply because they changed out to a three-prong recept.?
Adding new wiring is a big jump from replacing existing devices.
Exactly. And in the case of adding new wiring, the Code specifically (and correctly) addresses the issue by ensuring that the addition complies with current Code standards.
So if you add on to an exisitng two-wire circuit, as painful and expensive as it may be, I agree with the Code that you must bring the circuit up to modern standards.
NOTE: The bold and underlines in the following quote are emphasis added by me:
As Roger pointed out 250.114 factors in here.
In short you can not plug in an appliance with a 3 wire plug into an outlet marked no-equipment ground. (Yeah that will be followed)
The NEC is between a rock and hard place, you can not make the NEC retroactive and require people to rip up their walls just because the two wire receptacle has worn out and needs to be replaced.
At the same time they do need to do what is reasonable to make the installation safer than it was.
That's the point. You cannot make people rip up walls to replace a worn-out receptacle. And you cannot prevent someone from plugging a grounded appliance into an outlet marked no equipment ground. But as i'd pointed out in my first post, the use of an adapter on an older install is no promise of a valid equipment ground anyway.
So what difference,
electrically, would there be between a three-prong recept. on a two wire system and a two-prong recept. with an adapter, with the ground pigtail connected to the non-existant ground of the cover screw or box?
There is absolutely NO difference electrically between the two!!!
As for Roger's post, I agree with him 100% all the way up to here:
...So simply put, we must keep repairs and additions that we do code compliant, even if we think we have a better idea,....
Now here's a point I think we can all agree on: The Code is NOT all-knowing, all-seeing, right? It would be impossible to produce such a document, with concrete answers for every possible situation. (Same holds true in my Cinema biz..)
Sometimes the guys (and gals) in the real world DO have a better idea, having the benefit of many situations and years of combined experience.
Bearing in mind all the points we have all brought up, is it possible that the Code is not being realistic on this issue?
To summarize:
The safest solution, but not the most pratical or realistic in the real world, already resides in the Code with the GFCI requirement. But in the thousands(?) of jurisdictions which do NOT require inspections/permits, how can it be uniformly enforced? And like the AFCI's what's to prevent someone (most likely not qualified) from changing the device after the inspection? (Which can be a greater hazard than the one we're supposed to be preventing.)
The reality is that in a two-wire romex system, no EGC exists. So what difference does the use of a two-prong recpt. with adapters or a three-prong recpt. make, in the sense of providing for equipment/appliances which have grounding plugs? Well, other than the need for an extra set of current-carrying contacts in the adapter, or the real possiblilty of a ground prong being cut off,
there is absolutely no difference.
So does that now leave us with a new Code proposal, overriding years of precedent, which will now require us to totally rewire any building when we need to replace the two-prong recepts?
The ultimate solution:
Adding a clause to the Code:
Allow the replacement with three-prong recepts., marked with "No Equipment Ground" !!
Sorry for the marathon post, but that's how I see it.
And a big thanks to everyone for thier input!!
