unhappy electrician
happyelec
times running out and I need help;
a photovoltacic power source for a dwelling shall be permitted to be connected to the load side of the service disconect of the other source, provided that the sum of the ampere ratings of oversurrent devices suppling power to a busbar or conductor does not exceed what percentage of the busbar ratin A) 130% B)120% C) 110% D) 100%
TVSS grounding conductors shal A) be isolated from the TVSS B) not be run in metal enclosures unless bonded to both ends of such encloser C) not be larger than 12 AWG copper D) not be longer than 20m
Not looking for a quick answer need help finding and understanding. Thanks
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
On my way to work so haven't got time to check part 2 but look at article 690.64 (B)(2) exception for your first question
lowryder88h
Massachusetts
Tvss
Tvss
Unhappy, Ques. (2) is found in 285.25, your answer is (B):D
happyelec
exam ?
exam ?
Thanks for your help before but I have two more- where can I find Answer too
a bonding jumper connected between the communications grounding electrode and power grounding electrocde systems at the building or structure served where seperate eelectrodes are used shall be not smaller than
A) 12 AWG CU
B) 10 AWG CO
C) 8 AWG CU
D)6 AWG
Ive come up with 6 but not absolutely sure
Thanks Again!
Bea
A) 12 AWG CU
B) 10 AWG CO
C) 8 AWG CU
D)6 AWG
Thanks Again!
You are correct 800.100(D)
