Grouch
- New York, NY
I'm working on a project where the client wants to back up 8 receptacles in a room, all on one 20 amp, 120 volt circuit, so that if normal power goes out, those 8 receptacles are still on with enough time to shut everything down. It's a room in a 4 story townhouse. I'm thinking of using a small UPS, but what UPS can I use where the output would hardwire to the 8 receptacles located around the room? Usually a small UPS has built in receptacles on its output. 20 amps x 120 volts, a 2.4 KVA UPS would be enough.
Thanks!
Thanks!
