Hey ya'll,
First time back in quite awhile.
I wanted to get your input on a unique application that I've never run into before.
Our client wants (8) fluorescent 2x4 fixtures with a dimmable ballast installed in a Telepresence Room (A virtual meeting room with cameras). They want each fixture to have its own wall mounted dimmer switch for a total of eight dimmers. Basically, a parallel type connection. They want to be able to dim each fixture individually without the need of dimming the entire room. This is to adjust the lighting in the room for the cameras. Keep in mind that they want to stay inexpensive. No fancy lighting controls.
I was thinking about using one branch circuit to power the lights, but I?ve heard of horror stories of shared neutrals and dimmer switches resulting in flickering lights. Since the lighting is sensitive to this room, is it overkill to route a separate branch circuit with a dedicated neutral for each fixture? That is the only way I can think of that would reduce the chance of potential problems.
Thanks in advance!
Thanks in advance!
