stew
- federal way,washington
The first thing in this inspectors report is a long discussion about the evils of Zinsco panels. I agere with most of his assesment there and would also recommend replacement. We divirge however on othe things like the infamous "double tap" that they all think is real dangerous. Heres where we really diverge"Ungrounded 3 prong outlets in various locations should be repaired. (ok so far) connect grounds if available.(good again). If no ground is present "repair" can be as simple as filling the ground slot with epoxy. Or string a ground from a ground source to the outlet. Some codes allow the installation of a gfci where grounding is not provided(some codes? ).In this case the gfci "may" work but cant be tested by" normal "means".. I really am unsure where theses folks get thier training or dream up these things!! LOL His normal means of testing must mean he gets an error code on his plug in tester. Needs to be educated that normal means is just press the test button.
