Dancing Genius
My friend in the UK has invented a radically different type of pool light. It is a low voltage, 'dry niche' type and the bulb is changed via a flush mounted deck box on the pool deck. We have a world wide patent on this product and are trying to bring it into the US, but are struggling to comprehend the US coding requirements as they differ significantly from Europe.
You can see an illustration of this at
{Moderator's Note: I removed the link to the web site, to avoid any appearance of advertising. If you want to know where to see this product, then send a private message to the originator.}
My understanding is that the deck box must be at least 4' from the pool wall. However we are struggling to understand the grounding requirements (in Europe no grounding needed for LV pool lighting) if everything is double insulated - which this product is.
We have a metal light reflector in the 'dry-niche' - everything else is plastic. The central umbilical cord and bulb shroud is stainless steel and stainless braided tubing. The deck box is obviously plastic sealed with double o rings to prevent water entering during eg pressure cleaning.
Any advice would be much appreciated.
with thanks:-?
with thanks:-?
