mstrlucky74
- NJ
So if you had two temp unit heaters that required #12 wireand could be run in mc cable would you be able to run out 12/3 as I show in oneof the pics then mount box and continue with 12/2.?Would there be an issue withthe ground in the 12/3. Would each unit heater need a separate ground thuseliminating the 12/3 scenario? Thanks.
