Can 2 3kw 1ph 208v heaters be installed on 1 circuit? I remember seeing something about 30a max breaker in 424 of NEC.
Correct on the 30 amp - see 424.3. Circuits supplying multiple units are limited to 30 amps, though if it is an infrared heater in other then dwelling, it can be on 50 amp circuit.Can 2 3kw 1ph 208v heaters be installed on 1 circuit? I remember seeing something about 30a max breaker in 424 of NEC.
Are the units listed at 3kw for 208v or at 240V. This would make a difference
