richwaskowitz
- Shelby Twp. MI, near Detroit
When we install variable frequency drives in large industrial facilities where they are supposed to have an ungrounded 480 volt 3 phase distribution system, we are instructed by the drives manufacturers to disconnect a phase to ground jumper in the drive's front end that is there to connect the common point of the three incoming line MOV's to ground. If the system is grounded however, the jumper must be left installed.
The problem is that these ungrounded systems can and do become grounded unitentionally at times with no-one taking any steps to locate and correct the ground, sometimes for very long periods of time. How does one deal with this? This can't be all that uncommon of a situation.
