As an electrical inspector I have come across an unlisted (by UL) and an unlabled LED window sign in a storefront window to a carry-out pizza parlor that I am inspecting.2005NEC Sec 600.3 requires listing and labeling of signs unless otherwise approved by special permission.
The sign is powered by a plug-in cord with a built in power supply UL approved, 120v.ac. to 12v.d.c. There is a port on the sign that accepts this cord's 12v.d.c. supply end.
How strictly should code rule 600.3 be applied?
Could the cord's built in power supply, which is not an integral part of the sign, be considered to be a power-limiting circuit supply, limiting maximum current flow on short or overcurrent, thereby protecting this sign and allowing the inspector to approve the use of this sign without a label?
Thanks
Thanks
