fred p
- Dallas, TX
I have a remodel job that the architect has decided to close one of the doors to the electrical room. There is currently a 2000 amp switchgear that is 9' wide inside the room as well as multiple 200 amp panel boards. The engineer is claiming that we only need 1 door because we have an unobstructed egress that allows us to not have to adhere to the double clearance rule. Can anyone tell me the exact parameters to meet the requirements of 110.26(C)(2)(a). Also, I would like your opinion on if you use 110.26(C)(2)(b) Extra working clearance, do all panels require double clearance or only the panels rated at 800 amps and larger.
