What would happen if you unplugged a 60 cell panel (~40V Voc) in sunshine and under load from a micro-inverter?
Also, if you unplugged the micro from the AC trunk cable?
you probably unplug things from wall outlets all the time which have much more load connected.
The AC output connectors from microinverters are usually (always?) load break rated; that way they qualify as an inverter disconnecting means per 690.15(A)(2).I'd be surprised if the AC connector isn't load break rated (per 690.33). Ask the manufacturer if you want to be sure. But you probably unplug things from wall outlets all the time which have much more load connected.
