ohmhead
- ORLANDO FLA
I see art 230.6 conductors considered outside the building .
Question service feeds coming into a basement level electrical room now its 4 x 4000 amp mains with 12 runs each Swbd run across ceiling 10 foot in rigid we are underground from pad transformers to basement wall meaning completely underground .
Now the feeders will pass thur the basement wall with 12 runs of 4 inch rigid pipe which is 2 feet thick and then pipe over head to gear 90 down into the tops .
This will be 48 x 4 inch conduits across ceiling in electrical room only.
From inside basement wall to gear overhead 10 feet tops .
Is this a code violation ?
Is there a article that states it directly .
I know these are unprotected from power companys transformers but are they what is you opinion .
We always pour these in concrete when passing thur a building but these are in the electrical room totally .
Thanks
Thanks
