J jackson Member Dec 18, 2014 #1 Trying to find the requirement to seal gap between stucco and light fixture. Thank you
Smart $ Esteemed Member Location Ohio Dec 18, 2014 #2 AFAIK there is none... at least no explicit requirement.
J JDB3 Senior Member Location San Antonio, Texas Dec 18, 2014 #3 Not to my knowledge in NEC. Perhaps some energy or local code!
mopowr steve Senior Member Location NW Ohio Occupation Electrical contractor Dec 18, 2014 #4 I've seen some lighting manufacturers specify using silicone to seal around fixture base.
G GoldDigger Moderator Staff member Location Placerville, CA, USA Occupation Retired PV System Designer Dec 19, 2014 #5 mopowr steve said: I've seen some lighting manufacturers specify using silicone to seal around fixture base. Click to expand... Which in turn allows the NEC to enforce those specifications.
