UNUSED OPENINGS
mark m.
New Jersey
HEY, GUY'S IAM NEW MEMBER HERE. I HAVE BEEN IN THE FIELD FOR 17 YEARS & I'VE BEEN IN BUSINESS FOR 11 YEARS SO, I HOPE I CAN HELP WITH SOME QUESTIONS & I HOPE YOU CAN HELP ME WITH SOME QUESTIONS.
I RECENTLY DID A JOB THAT REQUIRED ADDING A BX WIRE TO A SIDEMOUNT 1900 BOX(WITH BX CLAMPS) IN AN EXISTING FINISHED WALL.THERE WERE (2)EXISTING BX WIRES COMING OUT OF THE BOTTOM, (1) BX WAS BEING ELIMINATED. THAT LEFT A SPARE HOLE IN THE BOTTOM OF THE BOX.(1 WIRE WAS STILL UNDER THE BX CLAMP). THE INSPECTOR FAILED THE JOB FOR "UNUSED OPENING". NOW I THOUGHT THAT WAS PRETTY UNREASONABLE AM I CRAZY?
I KNOW THEY DON'T MAKE A KNOCKOUT THAT SMALL.WHAT DO I DO WITHOUT TAKING OUT THE BOX?
NOT TO MENTION THE FACT IT'S IN A HOTEL & THERE'S A BUNCH OF THEM DONE ALREADY.
MARK M.
scotty
Connecticut
Re: UNUSED OPENINGS
Mark, your right this stinks, but according to nec 370-18 we have to close all unused openings. I to failed a job inspection for this and the inspector may a remark about soldering back the old k.o's. That didn't sound right to me and besides I only had two boxes so I changed them, but here's one for everyone to pick on how about firecaulk?? A fellow electrican gave me the idea, but I never ran it by the AHJ??
landelectric
Colorado
Re: UNUSED OPENINGS
Two flat washers(one inside & one outside) about 3/4" O.D. with a 8-32 screw and nut should be acceptable. (use a very small butterfly if you don't have access to both sides)
You said "wires" were coming out of the box, I assume you meant CABLES ?
[ February 24, 2003, 10:08 PM: Message edited by: landelectric ]
mark m.
New Jersey
Re: UNUSED OPENINGS
HEY LANDELECTRIC YEAH THAT IS WHAT I THINK IAM GOING TO DO. (YES, I MEANT BX CABLES.)THE ONLY THING IS THAT IT'S NOT UL APPROVED.
mark m.
New Jersey
Re: UNUSED OPENINGS
DELL, DO YOU MEAN JUST LEAVE 6" OF BX GOING KNOWHERE. (STUB)? WE LEFT A COUPLE DISCONNECTED IN THE BOX , WIRENUTTED & HE APPROVED THEM GO FIGURE.
Re: UNUSED OPENINGS
Yea, that's exactly what I meant, but it was tongue-in-cheek. I didn't expect it would be approved, although now that you mention it, I wonder what it would be in violation of? Anyone?
BTW, welcome aboard! (And all caps is genrerally considered to be shouting; figured I'd warn you before somebody shouts back) :)
[ February 24, 2003, 10:36 PM: Message edited by: dellphinus ]
landelectric
Colorado
Re: UNUSED OPENINGS
about the UL listing.
I don't think you would see a UL on a box of bonified KO seals anyway, so fender washers should be good.
It's reasonable and it's safe, if your inspector has half (1/2) a brain, he should accept it.
The nutted off cables to nowhere are a bummer dude !
mark m.
New Jersey
Re: UNUSED OPENINGS
THANKS FOR THE SUGGESTIONS. I HAVE NO INTENTIONS ON LEAVING CAPPED WIRES IN THE WALL MY POINT WAS THAT THE SMALL HOLE WAS A BIG ISSUE.
THANKS MARK M.
hornetd
Maryland
Journeyman Electrician, Retired
Re: UNUSED OPENINGS
MARK M.
My solution was to take aviation snips to internal romex clamps and cut away the part that would cover the opening still in use. I remove the screw holding the AC/MC clamp in place, slide the modified clamp behind it, and reinstall the screw. I won't claim that I can quote chapter and verse to justify that but it works from the inside of an existing box and provides effective closure of the unused KO.
Tom
