A real estate agent I do work bought a house{for his growing family}& due to an unfortunate accident must sell it asap. My 1st question is, do I need to install wall sconces to replace fixtures installed by the original owner or can I blank up the boxes & remove the switch for them? The sconces are not a primary lighting source,ther are 3 hi-hats in the foyer also.My 2nd question is reguarding a 100 amp fused disconnect switch mounted next to the 200 amp main panel.Another contractor evidently used the line side lugs of the switch as a splice point for the house A/C unit. Its fed from the main panel by a 60 amp D.P. with #6 CU conductors.At the switch the gauge changes from #6 to #8 in 3/4" EMT & goes to another box near the furnace.The wiring method changes again to #8/2 NM.There is no EGC in the conduit {intend to run one}.I think the conduit will pass once the EGC is run but what about the disconect switch turned splicebox? At best its poor workmanship.I could not find anything about either problem in the code.I appreciate your input,thanks very much.
