There are several items you shall look at before doing any lighting design.
1. What kind of ceiling it is? Dropped ceiling, open ceiling with joist? If it is dropped ceiling, you may use recessed luminairs. If it has space between joists, you may install luminairs there.
2. How big the space between the crane and ceiling is? It will define if HID fixture or High-bay firture works.
3. What is the room temperature? The light output of HID fixture is not affected by ambient temperature, but High-bay is.
4. How dirty the place will be?
5. Does it matter with dark spot under crane? If it is does, some wall mounted fixtures may help with that.
6. Does it require any shatter resistant protection?
I guess the lighting application is general lighting for the room. After you find out the answer to those questions. You will be able to nail down what kind of luminaire and lighting layout for your project.
