I have a customer who has a row of light poles he has controlled by a feed thru timer( the ones with the trip switches) What he wants to do is be able to throw a switch down at the timer to go from "manual" mode to timer mode. In manual mode he wants to control the lights from a standard wall switch.
So I thought of this, its hard to explain but i will try. I will put an offset nipple off the timer to a handi box with a three way switch in it. I wiil then remove the load wire to the lights off the timer and thru the nipple to the common terminal on 3way. A new wire from the load on the timer will go to one of the traveler terminals on the 3way. When the switch is in this a postion where these contacts are closed we will have timer mode.
Now for "manual" mode I will run a wire from the line in the timer thru the nipple and splice on to a two wire switch loop up to a single pole upstairs. The other end or the switch loop will go to the remaining travler terminal. Now when the 3 way is moved from the postion it was in the upper paragraph, it will be controlled by the switch loop of the single pole only.
I have never done anything like this and was wondering if anyone sees a problem.
