UP TO 6 DISCONNECTS?
drtymex
Just wanted to be sure if the wording nec just considers anything tapped ahead of the service disconnect allowable,whether it be an outlet or a 7ton ac unit as long as it is fused or has ocpd.Is this correct?
Does section 230 that covers upto 6 disconnects on one service located in one area include let's say a disc. for an 20a ampere outlet,if fuse properly?
Well in short ,do the 6 disconnects have to just feed panels?Or does the code consider a disconnect or an ocpd sized or fused properly,no matter what the disc. may be feeding,as mentioned before from a 20a ampere outlet to a 7 ton a/c unit?ANY AND ALL RESPONSE WOULD BE GREATLY APPERCIATED.PLZ MENTION ANY AND ALL CODE REFERENCE.
