dbjeffries
New member
- Yucca Valley, Ca.
I run across homes that don't have a ground rod, but are simply grounded to the water pipe. I was wondering if, since new homes have a ufer ground, as well as a gas and/or cold water bond, should these older homes without ground rods have them installed. If so, why, and if not, then why? I figure that the additional grounding is needed for extra safety...perhaps any of you have some safety information or a location to read on that.
Thank you.
Thank you.
