goldstar
- New Jersey
- Electrical Contractor
I'm upgrading an existing 200 amp (underground) service that currently has an FPE 200 amp main breaker panel. There is no need to replace the meter enclosure but I will have to upgrade the grounding. I'm not sure if the majority of you across the US have to do this but we here in NJ have to bond across the water meter. The existing ground wire is a bare # 4 (copper) and is properly installed directly to the point the water line enters the residence. I will have to move that so as to be able to bond across the water meter and in doing so will I not have enough ground wire to make the solid span. In your opinion would it be acceptable to use a high-press crimp like this Ilsco AS-4 to extend that ground wire ? I've done this with generator installations and have not had a problem. Just curious to know what kind of inspection crap I'll run into.
http://www.ilsco.com/e2wShoppingCat...k=2100001183:3100012197:3100012379:3100012779
Thanks
Thanks
