Ups
I have 400a 480v 3 phase load that will be supplied thru a UPS system. The primary input and output are the same voltage .How do I calulate the load comsumed by the UPS system alone ???
Les:-?
brian john
Leesburg, VA
Several factors will play into this issue, volts, amps, power factor, (KVA/KW)percentage of load, efficiency of the unit, typically a fully loaded UPS is more efficient that a lightly loaded UPS.
UPS manuals are at best limited in useful information IMO.
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
Hence the "can you speak German" comment. But it was easy to get the info I needed. These people spend alot of money on these systems. Customer service has been outstanding.
brian john
Leesburg, VA
I have found customer service to be a mixed bag of help. Like most things it depends on who you get. Had one tech I had to explain to him how the Aux I/O Bypass cabinet was to be wired, other tech are a wealth of knowledge.
I now get the German reference (bit slow here).
robbietan
Antipolo City
Les:-?
depends on what UPS you have. If its a standby UPS, probably negligible as these consume power only when its battery was used. If its an online type, a slight load may be added, as losses from the AC to DC conversion
dbuckley
I'll assume that a UPS of that size is an online UPS, for which there is usually a full load efficiency supplied in the manual, and the power consumed by the UPS is the few percent between the efficiency and 100%. And its usually a VA percent. So if you have a 100KVA UPS that is 96% efficient, then do (load / efficiency) * 100 to get total load, so (100KVA / 96) * 100 = 104.16KVA.
On top of that you need the recharge load of the UPS, and for that you will need the manual.
